rat4020
- Oct 28, 2011
- Cold Spring Minnesota
- Polaris and Turboed Apex in a off road buggy
Are there any members here that installed a Fuel Tech system in their Apex motors I could use some help with mine LOL
rat4020
- Oct 28, 2011
Nobody ae?
Its I installed a Ft450 with a universal 4cyl harness. Not much support after sale. Got a pos out of the supposed to be negative trigger for the coil and injector relays main is normal
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Been meaning to ask you are using the oem voltage regulator/rectifier correct?
You're saying the coils are wired wrong or opposite of the injectors?
rat4020
- Oct 28, 2011
Got 12.4 volts showing on the display. And I was thinking the same about the injector wires I guess I didnt think it mattered though
rat4020
- Oct 28, 2011
I looked up ID 1050.48.11.14.4 wiring and there's or they say pos and neg makes no diff when wiring them
kinger
- Jan 17, 2005
- Clear Lake, IA
How is it running?! Ya flying yet!
rat4020
- Oct 28, 2011
spent an hr remote tuning with Fuel Tech and it’s all good. The person who sold me the ft450 had about everything wrong and don’t ask me what he all did cause I couldn’t keep up with the pointer on my laptop as he was tuning . My bad for not contacting Fuel Tech from the beginning that would’ve saved a lot of frustration. It’s running very well now. I still have a lot to learn about the Ft450
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
@rat4020 check out this thread for ignition timing information. https://ty4stroke.com/threads/stock-ignition-timing-on-apex.108981/#post-965978
rat4020
- Oct 28, 2011
Thanx Allan, good timing info I am adding thermocouple into the collector along with a EGT conditioner before I go any further. Buster Brown showed up yesterday but the thermocouple lead is way too short so another week wait.@rat4020 check out this thread for ignition timing information. https://ty4stroke.com/threads/stock-ignition-timing-on-apex.108981/#post-965978
Any chance you can send me the fueltech map? I just need a startup map to my apex that I'm installing a ft550 on. What did you do for coils? Oem with ignitor or short vag smart coil?
rat4020
- Oct 28, 2011
The map I have is not tuned it starts and runs good but timing is off I am doing some more updates and adding more functions to be controlled by the ft450 after that is done I plan on having Straight Line performance dyno it.
i have the Fuel tech smart coils.
