timberwolf
What are the advantages to a fully clipped track vs every 3rd???? IDK what they are!!
I believe a fully clipped will give you less friction on your slides and it will help the slide wear because it lets more snow in. But it may be heavier than the every 3rd window. JMO
Groomerdriver
The biggest advantage is less slider wear. The added weight doesn't mean jack in the grand scheme of things.
At minimum, open up the closed holes with a hot razor knife or use the appropriate diameter hole saw to cut them out.
wayfastkev
Every third window- better flowtation
Clipped every window- extrovert drivers.
timberwolf
K thanks guys!!!!
Sasquatch
- Apr 17, 2004
- North Western Ontario
- www.dptc.com
- Yamaha's
wayfastkev said:Every third window- better flowtation
Clipped every third window will not give you better floatation. I will however give you hotter sliders and lots of melted plastic.
SNOW HO
SASQUATCH has it right! . and i think the fully cliped track with external Drivers is a great improvement for 2010.Sasquatch said:wayfastkev said:Every third window- better flowtation
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Another thing to consider is the lug depth and the HP of the machine . The deeper the lug with higher HP sleds the more chance of ratcheting on the every third window tracks. There is some added rotational mass with fully clipped tracks. IMHO I think it's more of a non-issue for a 4 stroke.......but can be a an issue on some 2 strokes speaking for sheer perfomance. The 4 stroke has a much broader torque band and will probably not be effected as much as a 2 stroke would.
03RX1-ER-LE
Bleed BLUE
- Feb 22, 2008
- 2011 Apex XTX 12,497 miles
2009 Apex ER 8,169 miles
Tow Vehicle
2021 Wolverine X4
- Livonia Michigan
Running kimpex 1.25 shotgun X with 96 1.450 studs in middle and full open track with every other window clipped, and it eats hyfax up. Think I am going to swap skids with one of my others and see if it changes or if it is the track design. My Son's that has a ripsaw with clipped every third and 96 1.450 studs in the middle does not eat hyfax anything like this one does.
- 7K
