12pointer
- Nov 24, 2012
- OHIO
- 2015 Viper LTX SE blue and white-Ulmer clutching, 8dn belt, MBRP trail can, J&T 4th wheel kit, Shaper bars,
does anyone know the amount of gear case oil to fill it. I sucked mine out and only got 7 oz. out . the level prior was half the site glass. So I am wondering how much is left in it or did I get most of it out.
Allan
Spec sheet I have says 355ml / 12fl OZ
Attacker
12 oz and site glass is half full. Just changed mine. Tried to suck oil out with a vacuum pump but couldn't get the hose all the way down so just loosened all bolts and cracked open the cover.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
I just changed mine put royal purple full synthetic 70-90. First time using any of their products. Its got quite the color to it.
TD Max
60% Cenpeco 70-90 gear lube 40% Transynd ATF. The Cenpeco oil has Temp Tac so it clings when cold like bar and chain oil staying on the parts. I put a bit over the recommended amount in so my sight glass is just at the full mark.
12pointer
- Nov 24, 2012
- OHIO
I was going to try and crack it but I got the most of the bottom loose but cant get the one on side under actuator loose . so dam hard to get on it . got pissed and tightened them back up . I don't know what to do. how are you guys getting on all these dam torx heads.
12pointer
- Nov 24, 2012
- OHIO
think its total bull crap Yamaha couldn't put a drain plug in it.
1/4in drive and a swivel if needed.I was going to try and crack it but I got the most of the bottom loose but cant get the one on side under actuator loose . so dam hard to get on it . got pissed and tightened them back up . I don't know what to do. how are you guys getting on all these dam torx heads.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Yamaha just supplied the engine some decals and friendly words of advise.
Get mad at cat. They designed the chaincase. Lol
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I changed all the bolts to 6mm hex head, those bolts suck. I think they are grade 3 bolts to boot, 1 step better than a shear pin.I was going to try and crack it but I got the most of the bottom loose but cant get the one on side under actuator loose . so dam hard to get on it . got pissed and tightened them back up . I don't know what to do. how are you guys getting on all these dam torx heads.
jsslye
- Nov 20, 2015
- Marilla, NY
- 2016 Yamaha SR Viper LTX-LE
Gone but not forgotten:
2009 Nytro RTX-SE
1999 Vmax 600 SX Triple
@STAIN - "One step better than a shear pin" - that's CLASSIC! So I don't want to start a Gear Oil War but it's funny how the Owners Manual says "The correct lubricant to use in the chain case is Synthetic Chain Lube" and the Service Manual states "Yamaha Snowmobile Chain Case Lube." My guess is because the Service Manual is dealer-oriented, but for the Owners Manual it doesn't even specify a gear oil weight, just that it's synthetic. Also for you guys looking for an inexpensive way to suck the fluid out of the chain case rather than split the case - go to your neighborhood boating/marine store and ask for the pump used for refilling the drive gear oil in sterndrives - it's a $10 pump that screws onto the top of the gear oil bottle.
12pointer
- Nov 24, 2012
- OHIO
I would like to have 5 minutes with the dumb #*$&@ who designed this. 1. No drain plug. 2 shitty #*$&@ soft metal torx screws. And 3. Rivot the bottom side panel so that it just tears the hell out of your arms. Oh believe me medical attention would be needed.
12pointer
- Nov 24, 2012
- OHIO
I just changed all mine also. its a must in my opinion. thank you for the advise.!!!I changed all the bolts to 6mm hex head, those bolts suck. I think they are grade 3 bolts to boot, 1 step better than a shear pin.
yamaha06
What length of 6mm bolts were you guys putting in, I plan on changing my chaincase oil tomorrow and would like to put 6mm bolts in instead, the stock bolts sound like junk. I'm at work right now and have a lot of different size m6 bolts to choose from lol, do you guys add washers too?
Genius
- Oct 8, 2014
- Goodrich IL.
- 2015 Viper XTXSE & LTXSE
I haven't changed the chain case oil on either one of mine yet, only 300 miles on them..
Question is....has anyone thought to look if there's room to drill and tap a drain plug in the bottom of the cover?
