Gear change?
BADSLED
Syracuse, NY
2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Looking for directions/tips how to change gear in Apex. Looks like the rotor has to be taken off. Just trying to make it as easy as possible for myself. Anyone?? :4STroke:
Yes the only difference is the reverse gears and fork and spring,and extra stuff related to your reverse,just be careful to remember where everything goes. Now just unbolt brake rotor after you take the E-brake off,just put rotor and e-brake up on top out of your way and remoce c clip on end of jackshaft and shims,again becareful to note where the shims go and how many you have,slide rotor off the key and shaft,now i think you are ready to drain oil or just take out your bolts for the cover,you may have 4 long and large bolts and may be 4 smaller and shorter bolts,than slide over the shaft carfully,if this is like my 03 rx1 that should be all there is to it,but the reverse gears,thats your problem lol i did not have reverse in my 03 so i cant help any further,except if you are looking for the drain plug,look way under next to the track for it.. ;)!
