XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
That's exactly what I did last year Dan. I think they want you to turn them 2 turns out. When I did that I said no way I'm running it that loose!I think we all had a consensus of finger tight then, "1 turn out". To be the sweet spot to not rub but not so tight to make the "wind" noise.
Dan
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
“Rub” on what? There is a roller and it’s spring loaded. The adjustment bolt acts as a limiter.I think we all had a consensus of finger tight then, "1 turn out". To be the sweet spot to not rub but not so tight to make the "wind" noise.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
The pictures that were uploaded where chain hits....“Rub” on what? There is a roller and it’s spring loaded. The adjustment bolt acts as a limiter.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
To answer the original poster we use Amsoil "Severe Gear" oil (which is an equivalent to brp synthetic chaincase oil) NOT amsoil chaincase oil.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Gotcha. Saw that. Mine was fine.The pictures that were uploaded where chain hits....
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Dan
I had a gut feeling that 1.5 turns out from a finger tight setting was much too loose, but whereas I broke it in by the book and maintained it myself by the book and was worried about warranty, I stayed with the 1.5 out per book.
If one follows the break in procedure and then the first chaincase inspection A(by the book), the sled has not seen much in chain stretching yet. Once broke in and lots of WOT short or long runs, the chain does stretch quickly.
I did have the dealer look at it while he had my sled, and yes 1 turn out should be the sweet spot.
The book should be updated to reflect that. Looks like I now have a stock looking color to my oil so I shall stay with what they installed until my next chain case inspection, then I will go back to the same type 75 - 90 Syn, I think.
Shall research the stock Yamaha chain case oil also. It looks impregnated through site glass, maybe graphite?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Any thoughts on why YAM wants such a large amount of turn-out? So many yrs of finger tight then 1/4 turn out its hard to do something different. lolGotcha. Saw that. Mine was fine.
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
Correct me if I’m wrong but I don’t remember the Yamaha tensioners being spring loaded? My Sidewinders is spring loaded so backing it off 1.5 turns is necessary so it does its job properly.Any thoughts on why YAM wants such a large amount of turn-out? So many yrs of finger tight then 1/4 turn out its hard to do something different. lol
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
You are correct about past and present tensioners. 1.5 is too much, any chain stretching and it shall rub.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I use to run ATF in my SRXs and Mach Zs back in the racing days. It's thin which is less resistance and if it's good for transmissions heck it should be good for a few gears and a chain.
In the winder I'm running Yamaha chaincase oil, not sure of the weight as the bottle doesn't indicate what it is.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Pstn head
Yamaha, Yamalube now has a synthetic chain lube, ill be trying that.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for pointing that out.
On their web site it claims that this oil is called out in the Viper and Sidewinder manuals.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Hi Guys
So what constitutes finger tight as that is pretty broad
XP123
- Dec 25, 2016
- Chautauqua NY
If your the six million dollar man you will break the adjusting bolt.Hi Guys
