jeff horst
- Sep 5, 2011
how hard is it to change the gearing on my 07 gt to rtx gears? is it to risky to do or do i need a mechanic? also my friend has a 06 er and his speedo is off by 5 km compared to mine any input on this ?
DV8
- Feb 9, 2010
- Howard City MI
- Attack and Axys
Its not hard, use a camera and lay out the pieces as you take them off, Remember to get the right gears if you have or dont have reverse.
Do a search also, I am sure some one has posted pictures already
ranger1
jeff horst said:how hard is it to change the gearing on my 07 gt to rtx gears? is it to risky to do or do i need a mechanic? also my friend has a 06 er and his speedo is off by 5 km compared to mine any input on this ?
If your buds speedo is off by 5 k's compared to yours, the question is how much is yours off? Most Apex speedos are off about 15 MPH at WOT (25 km's!) compared to GPS. Grinding off one tooth on the spedoo gear brings it within 7-8 from GPS & taking two teeth off makes the speedo almost bang on compared to GPS.
I ran mine up to exactly 100 mph on the GPS & the speedo was right on 115.
ranger1
By the way, what year RTX did you want the gearing from? In 08 the RTX changed from 22/38 gears to 24/38. I presume the older RTX as the newer one would have the same gearing as yours.
jeff horst
- Sep 5, 2011
ok thanx guys i wasnt aware the rtx changed...i was just told numerous times the rtx is much quicker out of the hole...so some guys have changed the gears in there gt's...and it worked great. must be the older rtx yes...
jeff horst
- Sep 5, 2011
also about the speedo i know the are off compared to gps but is each sled that much different? or how can u fix or figure out if its accurate?
ranger1
The RTX 22/38 will be quicker out of the hole as long as you can get it to hook up. Are you running studs? I don't run studs so I find the 24/38 combo hooks up for for me better (don't spin as much).
I believe all the Apex speedo's are out about 15 mph at 100 mph, not sure if the new ones are better or not though. Just compare your speedo to a hand held GPS to see how much yours is out. Let us know how you make out.
I think Yamaha uses the same pickup drive bearing setup in all their sleds as of late. I have an apex pickup hooked up to my rx1 and it works just fine. Its still going to be a dream meter though. lol
Mad Russian
my 2011 apex xtx read 117mph and my gps 115 . so they did fix the problem for the most part
