what is the engine maintenence,on the 4stroke 3cylinders,also are they fairly easy to work on,im a do it myself kinda guy. also what repairs have you guys had to do so far on the vectors(if any).thinking of taking the leap to a 4stroke but would like to know more about working on them a little more and there maintenece program.
thanks,redmater
thanks,redmater
Tork
Not really much to do. You could get a carb sync. Plugs every 2nd season. Other than the first one, changing oil before 2500 miles and filter before 5000 miles is a waste because in the snow the dust and dirt are down.
Part of the beauty is you dont need to do much except enjoy your sled.
You could grease your skid every 500 miles, that wont hurt.
p0wd3rp1l0t
nothin really, only thing i have done to the engine is changed the plugs at 1900mi, changed oil at 500mi but other than that i havent done anything other than that
stevenknapp
I did the carb sync myself and the idle is really smooth after I'm done. It was *really* easy and gave me some quality time with the sled. Valves need adjustment at 24k or something crazy.
I don't see this thing being any harder to work on then my motorcycle, which is to say pretty darn easy.
impalapower
Even if you didn't change the oil, the engine will outlast the chassis. But be nice, change it and grease it. Thats it.
SKIDOZER
REDMATER I LOVE MY VECTOR DO NOT MISS MY MXZ700 SKI DOO AT ALL
sled is great on fuel plus no 2cycle oil to buy
I ALSO LIVE IN EDEN NY WHAT A SMALL WORLD
sledheadgeorge
You could adjust the valves at 60,000 km or aprox 38,000 mi. Thats only if you had to.
SKIDOZER said:REDMATER I LOVE MY VECTOR DO NOT MISS MY MXZ700 SKI DOO AT ALL
WANT TO TY RIDE SOMETIME.. LOTS OF SNOW OUT THERE.
It seems that the WNY region is well represented in this forum. I as well am from Chautauqua Co. We're practically neighbors. Was out last night - snow was great and still coming!
SKIDOZER
we will have to get a ty ride together for next year
i beleive rx1liter is from your county also
blackbay2005
Does any maintenance need to be done on secondary clutch. (grease?)
bcoon
Western Ny represented again , rode out of byrnecliff last nite trails are great!!!
The secondary clutch itself runs with no grease. I'd recommend a good cleaning on occassion and a light coating of grease on the jackshaft before sliding the clutch back on.
blackbay2005
Thanks Chance
It says in the book to replace Drive chain oil every 3200km!
Is this necessary? Seems to me it should last longer than that.
impalapower
blackbay2005 said:Thanks Chance
It could last longer, its just gear lube.
