radianguy
- Jan 1, 2007
I had my reverse lever freeze up once on me, I spray it once in a while now with rust check and it has never frozen up since. I also spray the inside of the tunnel with rust check, helps keep ice build up to a minimum.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I took a can of WD40 and sprayed the lever and moved it around a lot. No problem with the freezing now. I hope it will keep the moisture away so it wont freeze over in cold weather. To spray the tunnel I have to wait for the temperature to rise, but I don't want that.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
Weldion - Thanks for posting your experience with the LED lights - glad to hear they are working out for you. I was thinking about going that route but Nick B introduced the angel eyes to me and I think I'm going to go that route now...
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I prefer the LED in front of the HID. The beam pattern is much nicer with the LED comparing to the HID in the Phazer. So thumbs up for the LED.
sloan188
- Nov 28, 2012
- Vaudreuil, QC
2009 Nytro XTX
Is your comparison based on the bulbs alone or did you install the whole HID projector in the phazer?
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Just the ordinary install in the original head light. No modification, just the H4 bulb install in the head light. So with that I prefer the LED.
stubb111
- Feb 4, 2012
- Ottawa area
- 2009 nytro xtx
theres a complete set of these shocks for sale on ebay a the moment
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Even thou it's snowing a lot right now it's time to put the sled away. Not so much riding due to bad conditions this winter. I moved it from my sled shed today in to my workshop to do a complete service.
Will powder coat my slide rails black and also send my Öhlin suspension away for service. So a complete overhaul really.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Should I get new NGK CR9E or should I get some other spark plugs? Any input on that?
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
I found the NGK Iridium IX (NGK CR9EIX) and according to NGK that is one of their finest plug, so I think I'll try that one.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
Moved the flashing indicator LED for the ROV kit to the spot on the side of the keyhole.
weldion
- Jan 13, 2013
- Offerdal
- www.weldion.org
- Sweden
- Grizzly 550 2014
And this is how it looks at the moment...
yamahamm
- Oct 9, 2009
- Norway, Salangen, Troms
- Norway
- 2008 yamaha nytro mtx mcx 270
I have to get me a set of those front shocks
radianguy
- Jan 1, 2007
Ive looked! Where would one get them?
- 12K
