powergrazer
Can get the mod. # of the 12'' glass pak that you guys have been using?
I found it 1 and lost where I wrote it down and cant find where I found it?
The guy who did the dual exhaust on my truck said he could only get 3.5''
die. glass pack and I saw the 1 was a 3'' die. that was being used by some of you guys!! Thanks and this is a AWSOME Site!!
YaMon
See my post at http://www.ty4stroke.com/viewtopic.php? ... highlight= It will tell you how I did what you want to do
powergrazer
Thanks YaMon that looks quite clean and slick!!
So you did not use the y pipe cut or did you?
Keep on Flyin!! I LOVE your signature. As I was a Beer truck driver for 10years!!
akvector
Hey power I am out here in the valley as well. What are you riding? I had muffler city do mine you can get a 3" up here in Ak you have to order it. I would recommend placing the glass pack where the stock muffler used to sit as to avoid your track hitting it. I am moving mine back I have it a classi muffler having it welded. I would not recommend muffler city again too much money for a glass pack. My track was only melting on the first 3 inches of the pack so by moving it back will allow me to keep the track loose. I would be happy to show you when I am done again!!
akvector
akvector
as you can see from that link Kachess's pack hits the track as well I will know soon enough if the relocate of the pack will do the trick. I am moving it back 10 inches.
YaMon
powergrazer said:Thanks YaMon that looks quite clean and slick!!
Power - Mine is on a Vector Mtn. The three pipes come into one then the exhaust clamps on. So to save length I cut the end of the glass pack off a little then I made slits in the remaining part to match the factory setup so that the clamp would compress around the gasket and Y pipe. I have not noticed any rubbing. I am using a 3" diameter pack though. I have not dropped the track to look for rubbing. Sounds really good and throaty. I would not want it any louder though.
- 6K
