I've seen problems with these relays on ATV's... it's not just a Yami sled problem.
Anyone know what colour wires go the fuel pump relay ???? I changed the 3rd one in from the outside. I was told that was the fuel pump relay. Like to make sure.
Winderallday!
- Dec 4, 2007
- SW, Ontario
- 2018 Sidewinder DX
Smokey said:Anyone know what colour wires go the fuel pump relay ???? I changed the 3rd one in from the outside. I was told that was the fuel pump relay. Like to make sure.
Changed my fuel pump relay under warranty this week (06Apex ER), even tho it wasn't pooched. It was the closest relay to the tunnel behind secondary. Supposed to be a problem with poor sealing allowing moisture in. Found the wiring diagram in the owners manual to confirm wire colors.
Kaz
Take the relay out and turn the key on and if you don't hear the fuel pump running you got the right relay.
On my 07AprxER the fuel relay is the outside one, furthest from the tunnel.
Kaz
