sneakattak88
Nice! Doing some myself Never again. Looks good from ten ft away so will go with it. You were wise having a pro do it for you.
Oldschool71
Looks awesome sneakattak88! Cannondale where did you get that tunnel bag?
Sent from my SM-G925V using Tapatalk
From Yamaha. The net I just picked up at dealer. Love having both. Can pack for a weekend easy and have room for hauling Pizza to hotel under net!Looks awesome sneakattak88! Cannondale where did you get that tunnel bag?
Oldschool71
Can you send me a closer pic of the bag and net? I would like to have a set-up like that.
Yes will pm you. Sorry for hijacking your thread sneakattackCan you send me a closer pic of the bag and net? I would like to have a set-up like that.
Oldschool71
I am sorry as well sneakattak didn't mean to hijack your thread.
Dinner
Wrap looks good! I've been throwing around the idea of wrapping mine!
nytrorider28
- Nov 14, 2010
- Marion, IA
- 2014 Yamaha SR Viper LTX
2007 Skidoo MXZ 600 SDI
Past:2009 Yamaha Nytro
Looks good! Now you need some orange on the front suspension.
alexm2816
- Mar 28, 2016
- SE Wisconsin
- 2016 SR Viper LTX-DX Turbo
I've got a new keg of PBR in the garage and a wrap kit to install myself. I'm a little OCD so I don't see this going well.
Cannondale, any tips? Did you do the float or pivot method? I've wrapped quads and dirtbikes, nothing this complicated. I'm only doing the hood and panels. Tunnel wraps look brutal.
Float using window tint spray. You will need a heat gun or blow dryer. Hopefully other side goes better for me. LearningI've got a new keg of PBR in the garage and a wrap kit to install myself. I'm a little OCD so I don't see this going well.
alexm2816
- Mar 28, 2016
- SE Wisconsin
The larger strips are hard. It looks pretty slick! Where did you get the tunnel wrap? It looks similar to the one's I liked on ebay but I always worry about the quality.
eBay and yes they don't fit well. Guy is supposedly fixing them after I got my $ back!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
If you have not done a lot of wraps I would highly recommend doing it wet..(LITTLE BIT of dish soap and water) Don't be afraid to spray the he@@ out of the surface and decal.. Get the decal in place first then GET a felt squeegee(for rookies)and or a hard card/decal squeegee work water out first(starting in the center or high spots) I like to use felt first and then in tight spots and curves the hard card)> then hit it with heat continue to work water out with hair dryer.. Do not just hold heat in one spot . You can overheat the vinyl and you get wrinkles! My 2 cents guys
Another thing is always work CLEAN .. your hands, your area, your clothes your vinyl install tools..
alexm2816
- Mar 28, 2016
- SE Wisconsin
Good tips.If you have not done a lot of wraps I would highly recommend doing it wet..(LITTLE BIT of dish soap and water) Don't be afraid to spray the he@@ out of the surface and decal.. Get the decal in place first then GET a felt squeegee work water out first then hit it with heat continue to work water out with hair dryer.. Do not just hold heat in one spot . You can overheat the vinyl and you get wrinkles! My 2 cents guys
Does mounting wet have any impact on the edges staying put? I'm sure it doesn't but i'm just paranoid i'll have an edge start coming up when the water dries.
