Thanks, looks like they may be sending sleds according to when they were ordered. Hoping that is the case as I ordered mine the second day of the spring checkI don’t remember the exact date , but I was the first one and ordered the day spring break was announced, This is the only one my dealer has gotten so far .
Port Yamaha posted a picture of the srx. It looks like yours are upside down. Look here:Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
So your sticker is on backwards? How come some are and some aren’t. In this pic it looks rightLooks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
Maybe you have a limited special collectors edition. One of kind. Should be worth and additional 5k don’t ya think. Looks like a nice sled though !Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
He has a call into the rep . If you switch them it looks like the electrical connectors will rub on the charge tubes . I am going to change them around when I get time and see .Your dealer is correct..I can see why too,my guess is the clearance would be to close because the a arm's sit higher.
Is the iqs sticker on the end of the actuator facing upright ?Looks like the shocks are mounted on the wrong side , dealer says not , they have changed the wiring connector this year . The Fox sticker is underneath
are the shocks on the wrong side ?Is the iqs sticker on the end of the actuator facing upright ?
I have never had a Yamaha blue sled .are the shocks on the wrong side ?
Yes they are , everyone that sees it loves it , even non sledders , I will change around , I thought maybe the new wiring connector would be to close to the tube . But not . ThanksHi Fox,
Great looking sled!
It appears the shocks are on the wrong sides, (Example Left is on Right, and Right is on Left).
