Greasable Control Arm Bushing Kits
Mainway Solutions
TY Advertiser
Vendor
Hamilton, On
Canada
WEBSITE
https://mainwaysolutions.ca
Mainwaysolutions.caMAK01 Kits tighten up those loose ARSII Front ends, No more squeaks and better tighter steering:)
I like that.. we should move this into the Sidewinder section. I think you will get more traffic on it.
love mine so far. Whole front end is so tight and smooth now.
I have the full kit works very well nice and tight. Only problem I have is getting them to accept grease on the control arms. Tolerance’s are pretty tight maybe they have to wear in some
Thanks for the reply, .003 clearance is tight. Your going to fill that cavity quick and the end clearance about .020 clearance so they don't slap back and forth. When greasing, 1 pump and let the pressure release. Greasing a sloppy hole is not much good but it would be easy:)
Are the uppers ok?
Are the uppers ok?
Upper and lower control arms are tight. There’s grease in them all Guess I’m just use to the old school ones where the grease would ooze out all over. Great product. Best part is the steering slop is totally gone
