- Jan 16, 2020
- Hamilton, On
- https://mainwaysolutions.ca
Mainwaysolutions.caMAK01 Kits tighten up those loose ARSII Front ends, No more squeaks and better tighter steering
Another great product!!
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Don't forget to add the bell crank bushing kit. This combo takes all the slop out of the entire front end.
The big one to me is the bellcrank.
- Jan 16, 2020
- Hamilton, On
I like that.. we should move this into the Sidewinder section. I think you will get more traffic on it.
- Jan 16, 2020
- Hamilton, On
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
love mine so far. Whole front end is so tight and smooth now.
- Jan 16, 2020
- Hamilton, On
Thanks For letting us Know!
- Jan 16, 2020
- Hamilton, On
Check out some of our other snowmobile Products
If you have any feedback on something you have purchased, that would be Great to hear your story
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I have the full kit works very well nice and tight. Only problem I have is getting them to accept grease on the control arms. Tolerance’s are pretty tight maybe they have to wear in some
- Jan 16, 2020
- Hamilton, On
Thanks for the reply, .003 clearance is tight. Your going to fill that cavity quick and the end clearance about .020 clearance so they don't slap back and forth. When greasing, 1 pump and let the pressure release. Greasing a sloppy hole is not much good but it would be easy
Are the uppers ok?
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
Upper and lower control arms are tight. There’s grease in them all Guess I’m just use to the old school ones where the grease would ooze out all over. Great product. Best part is the steering slop is totally goneThanks for the reply, .003 clearance is tight. Your going to fill that cavity quick and the end clearance about .020 clearance so they don't slap back and forth. When greasing, 1 pump and let the pressure release. Greasing a sloppy hole is not much good but it would be easy
Are the uppers ok?
- 6K
