Gremlins or Growling Noise
blackice
New England
Tried a search, but no luck. Guess I don't have it down yet, because I don't get specific results.
I have a used '03 Shorty with 1700 miles. It has a 1-1/4" track and 144 picks. After two Cats broke on Sunday, I started hearing noises. Kind of a growling coming from the front of the tunnel. The trails were hard packed and it seamed to happen at lower speeds. Seems if it was a shaft or bearing, it would squeal or grind. Was I hearing gremlins or is there something to be concerned about?
I'd read the posts on the jackshaft bearing regarding the jackshaft bearing keeper in the secondary clutch side.
I noticed mine makes a growling sound too after I changed the track. I only hear (and feel) it on deceleration. Mine sounds like the front left side of the tunnel. Like either the speedo bearing or the jackshaft bearing on the left side. But again only on deceleration.
I'll be watching to see what you find. good luck. PB
