blue sled
- Jan 8, 2008
i have an 07 apex er at 1200 miles it sometimes does not go in to reverse and makes a grinding gear spinning sound is it an adj. or take it to the dealer 4 hours away the dealer close to me said it could be from dealer set up and warrenty might not cover it they get $89 an hour some times it works . the shaft on the gear box moves in and outabout a 16th. of and inch. just started doing this so i stop riding it.
mine did the same thing,pop right panel off,and adj the linkages.never had a problem since.your fine if you go fwd.make sure your chain tension is good before you start!!
blue sled
- Jan 8, 2008
thanks
its fine going foward thanks i will try to adj. it . adj top linkage or the bottom linkage? thanks
PeeWee
I had the same problem at about the same time. The linkage is out of adjustment slightly. In my case the shifting fork was worn and needed to be replaced. The chaincase cover has to come off to be sure.
![](/styles/vip.gif)
Shiek
reverse adjustment
Adjusting Step 1 - Upper Linkage
Loosen locknuts and set the length between the locknuts to 27 mm
Tighten locknuts
Adjusting Step 2- Rear Lower Linkage
Loosen locknuts
Turn the threaded adjuster to decrease distance between locknuts
until freeplay is removed, then turn threaded adjuster back 1/4 turn.
Tighten locknuts
Adjusting steps as per Yamaha Tech Tips
Tighten locknuts
Loosen locknuts
Tighten locknuts
blue sled
- Jan 8, 2008
adj.
adj . working great so far dealer said its 500 mile adjment adj. chain to.
catchmeifucan
Same problem here. Was searching and found this thread. Thanks
SharkAttak
Re: reverse adjustment
this adjustment work's awesome, the reverse is picky, but if you do this to spec it will be right on![Div20 ;)! ;)!](/styles/default/xenforo/smilies/div20.gif)
Shiek said:Adjusting Step 1 - Upper Linkage
Tighten locknuts
Loosen locknuts
Tighten locknuts
347strokin
Your dealer should adjust it under warranty. My dealer just did an adjustment and changed my oil after inspecting the gears. Never had a problem since.
