grizzly660 top speed low eversince first service
mtnkid
PG
I used to be able to get my grizzly up to 100kph before my first service now i can only get it upto 89kph does any1 know why?
I have 3000 kms on it now and 250 hrs and its 8 months old could it just be from wear ?
What was done during your first service?? Maybe a valve adjustment?
If the valves were adjusted improperly you could loose power. I know I can tell when mine is in need of a valve adjustment it is slower then normal and after I adjust the valves its like a new machine all over again.
Maybe adjustment is off? The wrong lash guide could have been used or the wrong line on the crank could have been used for TDC.
I ride it in lots of mud and water mostly upto the racks could water be rusting something out and seizing it up?
