jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Absolutely. Not sure if I will be keeping it(CAT), but I would do that for sure..I'm meeting with my machinist today to go over my next big idea regarding this drive shaft issue. Been really wanting a fix that will work on a worn shaft and I pretty confident I can do it. If you are not in a rush to fix your cat I could possibly send you some prototype parts once I have some made up.
Interested either way what you come up with.. Thanks
Dave385
- Nov 12, 2017
- Michigan
- 2018 Yamaha Sidewinder
2008 F1000
2007 F1000
2007 F1000
- Lapeer Michigan
Hello Guys,
Dave from DMC,
Thank you for all of the positive feed back.
We have a our DMC HD gears and Brass shift fork pads in stock. We are are also working a Germany OEM to provide our exclusive HD chain case chains.
Dave from DMC,
That'd be great. Hope you can have it more affordable than Cat.Hello Guys,
Dave from DMC,
Holy, I think Cat parts are very expensive lately.
Turboflash
- Mar 18, 2019
- Southern MN
I don't like the inches of slop in the reverse chain either. IMO, that chain needs a small tensioner or it needs to stretch less than it does (need a HD chain). I'm just waiting for a time when it skips because it's so loose, and then takes out the chain case or something.
So stock 21 tooth gear is on back order and who knows for how long (sled still under warranty)
If I have to buy an aftermarket gear is there any advantage going with 22 tooth?
Sled is not tuned, just clutched.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Pretty sure I have 1-2 of those. One is brand new I believe. Shipping might be long and pricey? PM me if you are interested
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
I'm in Ottawa and have one brand new from my '22.So stock 21 tooth gear is on back order and who knows for how long (sled still under warranty)
Mototown
22t difference in gearing is 4-5 Mph top end on sled if on hard pack or ice . Bottom end is a little slower if stock . Positive is the chain has less deflection and has less chances of hitting inner post if chain adjuster is loose with the 22t . But if you do your maintenance the 21 is perfectly fine .
2022 top gear
3500mile
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Someone is coming to see me today.
Mototown
Bushing needs replaced, probably the easiest fix , is get a bushing from provost in north bay if u don’t want to buy a new gear
Lol
Likely not today
Need to decide if aftermarket is the way to go
Likely not today
Mototown
Yes get a better bushing, it will happen if you leave it. You don’t need the shift fork pads . Just spot weld or lock tight the chain adjuster while you are in there
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
But I have the super duty upgraded in 2022 gear for him. The new bushing is even a blueish colour. Can't get that with aftermarket. lol
LolBut I have the super duty upgraded in 2022 gear for him. The new bushing is even a blueish colour. Can't get that with aftermarket. lol
Ya my 22 was supposed to be super duty
- 41K
