My good friend @craiger68 bought a 2020 Viper for his wife and asked me to install GSE Power Steering Kit for him. I said sure why the hell not!! I just wanted to stress the fact how easy of a job it is and anyone that is afraid to do it should not be... its a cake walk!!
I am going to give a quick over view with some pictures and if you want to see the full instructions <Click Here>
Remove Seat, Side Panels and Hood:
Here is the kit in a nut shell:
Remove Air Box:
Remove Handle Bars and roll them back onto the tank:
Remove the push pins that hold the left side steering boot on, remove the nut on lower tie rod from steering post, remove the steering post base nut (access from underside by boot), remove the 2 nuts that hold steering post retainer and lift out the steering post.
Install new steering stub shaft and bolt as noted in instructions and bolt short tie rod back on.
Remove engine mount bolt nuts only as directed, slide motor on per instructions, drop in power steering mount as noted and bolt in place.
Install top portion of steering shaft as noted in directions and reinstall retainer.
Reinstall the handle bars:
Install the power steering control unit on the power steering bracket and plug in all the wires. They only go in one way.
Route and zip tie power along the harness on the clutch side and tie into the battery as noted.
Here is something to take note: the instructions say to tap into an orange wire on the clutch side harness as pictured in the PDF instructions. We could not find this wire. So after a quick call to GSE we found out it needs to be tied into a keyed 12V source. The red wire with blue tracer is a 12V regulated source that's the same as the accessory by the reverse motor. You will find this wire on the bottom side of the main plug that goes to the hood.
Here she is all complete. Be sure to read all the instructions carefully and follow them as noted. Be sure to double check all connections and fasteners.
@GSE Performance
Remove Air Box:
@GSE Performance
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
Are those the stock ski?
RAMSOMAIR
Are those the stock ski?.........thats what you got from all of this lol. And no, not stock skis.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
LOL!! Is that the medium windshield???Are those the stock ski?.........thats what you got from all of this lol. And no, not stock skis.
Seriously, great writeup! Doesn't look bad at all!
Those are C&A skis and the stock windshield that came on the sled. Thanks for noticing the power steering write up. Lol
I can’t wait to hear your review after riding it. My mother has a Viper and had shoulder surgery recently. I think this might be a perfect addition to her sled.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
I have an MPI kit installed on my 14 RTX and I do not think I could shoe-horn the power steering kit in there but I did notice the single keel on the ski. Nice job on the photos. Do you have a photo of the kit installed before the hood was put back on? Looks like a well built kit.Are those the stock ski?.........thats what you got from all of this lol. And no, not stock skis.
it sits well bellow the crossover bar if that helps. Should be able to see that from the images that are posted.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
All I noticed was the Casters on one of the tool chest were turned out and are a tripping hazard and the rollers on your Garage door look like they need Lube !
Excellent write up and Great pictures ! I look forward to hearing the feed back on this kit and the new sled .....
Wow that looks factory! Maybe better. I am impressed.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Great work Tom, awesome install should work beautifully
Yamadog
After all of that and no one noticed the chassis diagram taped to the inside of the lid of the stainless tool chest on picture #1. Come on boys pay attention. It looks similar to the upgrades I made to the 2011 Pro R - then it blew up I believe it was too much cylinder pressure.
After all of that and no one noticed the chassis diagram taped to the inside of the lid of the stainless tool chest on picture #1. Come on boys pay attention. It looks similar to the upgrades I made to the 2011 Pro R - then it blew up I believe it was too much cylinder pressure.View attachment 150437
Right on!! Amateurs.
Yamadog
I guess I could have written an article as well maybe how to install a can on a 2 smoke, or going to oversized jugs makes for a stiffer ride?
