Mods
- Nov 27, 2014
- Ottawa, Ontario
- 2014 SR Viper LTX
Trying to figure out what would be best for me, I weigh about 150lbs and do mostly trail riding with the occasional off trail.
Currently I have it set to around 75psi, not sure how I feel about it to be quite honest.
60psi
weasel33
That sounds pretty high for trail riding. When I had those on my nytro I ran around 63 - 65 psi.
Mods
- Nov 27, 2014
- Ottawa, Ontario
- 2014 SR Viper LTX
I'll try toning it down a bit, I haven't actually had it on the trail yet, this is experience from the back yard and some rough trails in the forest.That sounds pretty high for trail riding. When I had those on my nytro I ran around 63 - 65 psi.
viipeR
- Aug 25, 2014
- Regina, Saskatchewan
- 14 viper XTX SE
i weigh 220 without my gear on. currently set at 65 front 135 rear and it works flawlessly. I'm a backcountry rider though rarely see trail
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
65-70
Zampinator
- Nov 22, 2014
- Gaylord, MI
- 2015 Viper XTX LE
Front 95
Rear 150
240lbs.
Rear 150
240lbs.
MorganKoda
- Dec 26, 2013
- Lakeville, MN
- 2014 SR Viper XTX
70-75 Front
140-145 Rear
140-145 Rear
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
65 pounds. That's about the best I found last year. They have a very small sweet spot. Any more and they feel stiff and all the trail bumps come right up the handlebars. Any less and they bottom out.
Mods
- Nov 27, 2014
- Ottawa, Ontario
- 2014 SR Viper LTX
Thanks for the input guys!
Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
60 psi in the front, 110 rear with 150 in the EVOL chamber. I weigh 170 and just added the EVOL shock, so I'm still playing around with the rear pressures somewhat.
Bill
Bill
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
If I run my fronts at only 60-70 I bottom to much and notice to much inside ski lift. I have been running 90 and thats about perfect for my riding style. Still bottom the front out from time to time.
yam177
- Aug 14, 2008
- Shoreview MN
- www.jbeurotech.com
I ran 220 in the Evol 150 in the main last weekend
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
So you guys all do your adjustments with the skis and track off the ground and in the cold??????
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
yesSo you guys all do your adjustments with the skis and track off the ground and in the cold??????
