Handlebar set ups
fxnytrortxkid
Rensselaer, ny
09 nytro rtx
Post em up guys. Let's see some custom cockpits, risers, relocators, bars, throttle/brake changes grips bar heater set ups. What u guys have? Love to see some pics.
My fly risers carbon bars an bar pad will be here tomorrow thinking odi grips and the yamaha curved brake lever. Love a throttle block also but still debating it.oft relocate will be added soon also once I. Get around to ordering one lol. And will post up pics once it's done
I'll have of find the pic other than the one on the left there but I went with Doo XRS alum bars flat bars (they are hooked on both ends) with a lakeeffect 5 in riser with ODI grips (by the way after one ride I cut the grips off of everything known and put in the ODI) Oft relocate with their custom mount for the pro armor teather mounted at the bottom of the riser and a RSI pad
Nice. Yea getting odi myself. Always ran them on bmx bikes with the lock on system. Loooved the lock on system. Wish these were like that. Went 4" thinking I wish I got 5-6
i have some carmichael pro taper se bars with a 3 inch fly riser. the bars have the oem polaris assault switchback/rmk bar ends. setup is about 3/4" wider on each side. nice feel.
Here's mine, grips still on way and need to get my heat gun to take handwarmers off previous bars, otherwise they are all on
Fly 4" risers fly carbon snox bars n pad
Let me know if you are able to successfully remove the OEM grips and reuse them. I have always wanted to try wider straight bar without sacrificing oem hand warmers.
I drilled rivets out then kept twisting grip in diff spots to break glue. I could then just pull them off. I will let u know for sure about the handwarmers when I take heat gun to them tomorrow
fxnytrortxkid...sweet set up, are you running a relocater too?
Not at moment, I really like bar location at moment. But I would like more natural bar path, so been considering the bdx kit. But afraid it moves the top of steering post to far forward. Gonna keep eye on threads and see if someone posts comparisons to them.
Forgot to add that I did the oft relocate after the first year of riding. Then got really mad that I didn't do it right away. Feel like I wasted a year of riding without it.
i used a razor blade starting from the hook to cut the grip away from the heater. once you get it started it comes off pretty easily. then i used the razor blade to cut the foam padding away from the stock bars under the heater and was able to get them off successfully. i used electrical tape under the heater when i reinstalled to avoid any shorting due to the foam no longer being there.
Drilled rivets. Kept twisting grip side to side to break glue. Once off removed electrical tape. Then I could peal off CAREFULLY the heater, basically just a big sticker. Worked great took 15 min. The results!
