handleing tips for 05 vector
cat hunter
Irish Quebecer, Canada
I have a 05 vector with snow trackers and i want it to handle the best, it currently pushes on the corners and is very easy to steer.I would like it to stay flat on the corners and corner as if it were on rails. Any tips would be very helpful, how do i set up my suspension and shocks aswell as transfer rod. Thanx :yam:
Well how much do you weight???????????I go 220 and mine is set-up with the front preload toward soft.. The middle shock the same. The rear spring at the middle, and the stopper set at full hard.. I didn't touch the limiter strap or the rods... Now the biggest improvement you can make is to put on studboy duece bars... It cures darting and they corner great.. 4 1/2" non studded, 6" for studs. MM. ;)!
