Does anyone else have idling issues with the notched cam gear and head shim. The idle screw doesn't seem to do anything and I have ran A/F ratios from 10 to 15 and it still doesn't want to idle. When setting the timing the intake cam lines up perfectly with the crank and the exhaust is slightly ahead (towards gas tank) of the mark. Any ideas.
BD turbo, 2 Yamaha gaskets, 1 aluminum shim, notched intake cam gear
