TRiGGeR605
Hey guys,
I have a 2007 phazer and the headlight keeps burning out and blowing the fuse. I have tried putting in a bigger fuse to remedy the problem and I'm still getting no results. It will blow out the fuse within 10 seconds once you switch from low to high beams.
Any ideas?
Any ideas?
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700, 2023 Polaris Boost VR-129
- Niles, Oh
You may have a short in your headlight harness. It happened to me on my Apex. Pull the fuse out and connect an ammeter in the circuit and see how many amps its drawing. What may be happening is that its trying to light both the high and low beam at the same time. If that's the case it will probably try to draw somewhere around 19 amps. Anything less than a 20 amp fuse is gonna blow.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Putting in a higher rated fuse is NOT a fix.
Is the bulb actually burning or is the fuse just just letting go?
You probably have a short somewhere.
TRiGGeR605
Only the fuse is burning out.
Macheater
- Feb 7, 2006
- Niles, Ohio
- Niles, Oh
What is the standard size fuse? And how big have you tried that blew?
- Nov 1, 2009
- 2009 Phazer RTX
ok, please only use the stock fuse (20A) as it is a circuit protection device. It is there to protect both you and the sled.
Amps will go up if there is less resistance, less resistance can be a short. Electricity takes the path of least resistance and if you have a short it will bypass the load (the resistance in this case the lights) and cause the amp draw to climb.
Look for a chaffed wire starting at the plugs. Make sure the plug is in good condition as well.
- Nov 1, 2009
- 2009 Phazer RTX
Or check for a short in the switch as well.
Check out the blue wire with the white stripe in your handle bars. It may have rubbed on something that's moving.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Another possibility is the filament within the bulb has shorted to another filament. I've seen this happen in taillight bulbs.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
If you have flipped your Display Pod, the wires will rub against the bracket and eventually wear down. Dont ask how I know.... Use a spliced rubber hose and wrap those wires.
