Headlight looks crooked?
RTX Rox
Toronto, Ontario
I had my headlight off my Apex last night to do some inspecting and when I re-installed it, it looks crooked. I had the airbox off as well and it's seated properly, the headlight is hooked into the tabs and the bolts on the side are tight, its just with the lines up the center of the cowel, the airbox and the center of the headlight just doesn't look right. What did I do wrong?
got a picture of it?
No pics. I did take it off and re-install but with the same outcome. I have it on my sled dolley (goes under the sled and picks it up from the running boards). Maybe it just looks that way. Before I tightened the bolts on the side I pulled on the light to make sure both tabs were hooked in and it felt like they were. I'll give it another try tonight.
if tabs are both slid on properly and both 10mm bolts are in each side,then it must be level.
my guess would be one tab isnt on maybe.
dan
