ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Is the headlight housing for the Viper the same as the Cat 7000? If so, the 2017 cat part number is 0609-967 and it's cheaper at 93.28 at partspitstop.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
No it is not the same. Cat's is a bit different design.
My 17 with the HID's are spot on like putz21 said, high or low. Never made any adjustment from factory setting. Wife's 16 with newly installed HID's are adjusted for low only as high is in trees. But they are so bright never switch to high anyway.
A quick travel limiter mod is all that you need to keep the high beams from pointing skyward. The bulbs just pull in too far for the housing reflectors. Rock has been doing this on his kits for the past year or so from what I understand.
putz21
- Apr 15, 2013
- Tomahawk, WI
I heard that Rock has updated his HIDs to help correct the High Beam issue. I bought mine in '14 so I didn't have the update from Rock so I just went ahead an ordered the new headlight housing. Either option should work great whether they are Rock's updated HIDs or the new housing.
parepadarappa
- Mar 27, 2008
- Sault Ste. Marie MI
- 2016 SR Viper X-TX, 2002 SX-r 600
Please fill me in on this travel limiter mod. I don't ride at night enough to justify an hid kit, but when I do (maybe 5 times a year) I've already given up on the high beams.A quick travel limiter mod is all that you need to keep the high beams from pointing skyward. The bulbs just pull in too far for the housing reflectors. Rock has been doing this on his kits for the past year or so from what I understand.
PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
I installed a 17 xf7000 light housing into my 14 viper without any issues. Works great.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- Columbus, Indiana
Can we get some pics to show the difference with the cat housing mounted in Viper bodywork?I installed a 17 xf7000 light housing into my 14 viper without any issues. Works great.
putz21
- Apr 15, 2013
- Tomahawk, WI
I had originally bought the '17 Cat housing, not knowing how different it looked at the front compared to the Viper Housing. Different look I didn't like so I purchased the '17 Viper once it came off of back order.
PAvector
- Feb 24, 2007
- Pennsylvania
17 housing currently in sled. Holding the 14 in hand on left.Can we get some pics to show the difference with the cat housing mounted in Viper bodywork?
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
I just got home from a great trip in Ishpeming with smooth trails and great snow. I have the rox led kit in my sled and sent them in this summer to have the update fix for the high low beam gap problem to be fixed. well it didnt work out so well. lows still to low brights still to high. I had meyer yamaha install a 2017 headlight housing in sled and took the led kit out and returned it back to stock bulbs. not perfect but much better than before. i could at least see where I was going. long story short the best set up I have found for general trail riding is stock bulbs with 2017 head light housing. So long story short save your hard earned money and just upgrade the headlight housing. nothing worse than being 75 miles from hotel in dark and not being able to see the trail!Visually, I cannot see any difference with my eyes. I've read that they have moved the high beam pattern down by 5 degrees. Just got back from another ride tonight. Absolutely love it now.
putz21
- Apr 15, 2013
- Tomahawk, WI
Put a set of Rock's HIDs in the 2017 Housing and you won't be disappointed!
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
X2. Awesome set upPut a set of Rock's HIDs in the 2017 Housing and you won't be disappointed!
trailtamer
- Feb 8, 2006
- Manistee County, MI
- 2014 Yamaha SR Viper LTX
My 2014 headlight with the Roc HIDs are sweet on low beam, shining for coons on high beam. After some research, this is what I found as far as different part numbers & prices go. Hmmmm!
2014 headlight Assy: 8jp-h4310-00-00 $201.56
2017 headlight Assy: 8jp-h4310-10-00 $112.07
putz21
- Apr 15, 2013
- Tomahawk, WI
That is correct. The 2017 housing is much cheaper and it works sweet!
Crap you guys are always making me spend $!That is correct. The 2017 housing is much cheaper and it works sweet!
