eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Are you using the “YS” weights or the “A” weights?
This is for a big turbo ZUK. Not a winder...
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yes that amount of weight seemed crazy.
Those are the weights I’m going to try, although I won’t be using the 72’s!!!
Thanks for sharing.
creep
- Oct 24, 2013
Any set ups with the HH that someone wishes to share?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Creep, I will get some for you from our customers
creep
- Oct 24, 2013
Hi TP,any updates regarding set ups?
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
My set up from last season that worked very well was Heavy Hitter base weight 58 GR. heel: long steel allen 3.4 GR. mid: short aluminum bolt .6 GR. Tip: brass bolt with 2 thin brass washers 5.1 GR. total weight 67.1 gram TP rollers, tp orange spring with 2 glid washers. driven clutch: TP rollers, TP orange at 3-1 33-35 TP helix XS 825 belt 8900-9000 rpm, engagement 2700-2800 RPM this was with TD Max Spool16, CAI, Turbo Smart BOV. overall ran excellent same belt all season. clutches never hot. just a little warm after a very hard pull. Hope this helps you outAny set ups with the HH that someone wishes to share?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
From one of our customers running an HH setup on the clutch.
270 Hurricane tune, 4 arm clutch, 48 base HH (total weight 56.2 total)
That's all the one sent me
