eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Are you using the “YS” weights or the “A” weights?
This is for a big turbo ZUK. Not a winder...
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yes that amount of weight seemed crazy.
Those are the weights I’m going to try, although I won’t be using the 72’s!!!
Thanks for sharing.
creep
- Oct 24, 2013
Any set ups with the HH that someone wishes to share?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Creep, I will get some for you from our customers
JPS
- Aug 23, 2014
- Clarks Summit, Pa
- 2018 sidewinder XTX, 2017 Viper XTX, 07 apex attack, 95 Vmax4
My set up from last season that worked very well was Heavy Hitter base weight 58 GR. heel: long steel allen 3.4 GR. mid: short aluminum bolt .6 GR. Tip: brass bolt with 2 thin brass washers 5.1 GR. total weight 67.1 gram TP rollers, tp orange spring with 2 glid washers. driven clutch: TP rollers, TP orange at 3-1 33-35 TP helix XS 825 belt 8900-9000 rpm, engagement 2700-2800 RPM this was with TD Max Spool16, CAI, Turbo Smart BOV. overall ran excellent same belt all season. clutches never hot. just a little warm after a very hard pull. Hope this helps you outAny set ups with the HH that someone wishes to share?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Hi TP,any updates regarding set ups?
From one of our customers running an HH setup on the clutch.
270 Hurricane tune, 4 arm clutch, 48 base HH (total weight 56.2 total)
That's all the one sent me
HMTurbo
Running the 60y myself and very happy with them.
What primary spring are you using and do you have any weight added to the arm (heel, mid or tip)
- 8K
