sneakattak88
Well I'm just playing now,,, I have a Nytro low boost trail rider,(200 hp) flat lander, I will be 100 % honest I'm lost on helix, sled runs good no complaints, just want to try to get that little extra , what I have now s the heel clicker in primary set at 8900 rpm,, in secondary I have stock helix (43 deg) with purple spring, I don't mind loosing in the trail , I want to gain on the lake, so was thinking going to a 39 helix? Can anybody send me in the right direction?
suburban
- Apr 19, 2003
- ontario
- 2021 SRX
That setup should have a wicked back shift. If it holds rpm where you want it not sure why you would want to change it?
DaveB
- Oct 17, 2012
Higher helix angle upshifts faster, but backshifts slower and has less belt grip. Low helix angles clamp the belt harder and backshift rapidly, but upshift/acceleration suffers.
If you want to go faster, you are going the wrong way on the helix. I run a straight 47 in the mountains with the purple EPI spring. This is PLENTY of belt grip for me so I would suggest it should be for you as well with a shorter track and running the flats. I am new to Yammy, but not clutching/clutch theory. I would suggest at least a 49 or 50 straight helix for flatland running...maybe a Yammy guru can confirm/deny my recommendation. You will lose some RPM, so you will have to drop some weight on your primary arms to compensate.
sneakattak88
Funny you mention str8 50 because I found that helix in my pile and it was on my turbo Apex,, I will try that one ,, on a nice day I want to kill time
