Yamirydr
- Jul 10, 2009
Got complaints from guys following my Nytro last year because the brake/tail light got covered over with snow all the time. Short of a fix for that wondered if any one has used a helmet mounted LED stop light.
Turtle
- Feb 27, 2006
- Marathon, WI
'07 FX Phazer GT
Yamirydr said:Got complaints from guys following my Nytro last year because the brake/tail light got covered over with snow all the time. Short of a fix for that wondered if any one has used a helmet mounted LED stop light.
Here's one I've been considering:
http://atlantispowersports.com/index.htm
You can also google "helmet motorcycle brake light" and find a few others.
Mr Freeze
- May 26, 2010
- Southwestern No Snow Ontario
- 2014 Viper XTX
My helmet has a led strip built in that flashes continuously.
Super Sled
- Feb 25, 2009
- Summit X
If you just ride faster they won't be right behind you to even see the light.
dansranger
My brother has one in his Bv2 helmet and it worked great. I went out and bought stickers that glow, but it does not work as good. The light really helps my eyes out on the nights when its snowing real hard.
BombaPolaYama
Sounds a bit goofy but I guess safety should take precedent over looks. Eh it may also help to locate guys who fall off and end up in a snow drift!gade-thrasher said:Yamirydr said:Got complaints from guys following my Nytro last year because the brake/tail light got covered over with snow all the time. Short of a fix for that wondered if any one has used a helmet mounted LED stop light.
Roz
Bud of mine has one in his helmet, works great. Only problem is that it is so bright, that you see the light far ahead and you assume it is a straight path between you and the light , meanwhile there may be a rock or a few trees to go around first before you catch-up to the light.
Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I frequently ride behind a buddy who also has the BVS helmet Riding in broad daylight the spin drift/snow dust will completely obliterate him. But I can always see his red LED on the back of his helmet.
Fourcam281
I have a BVS too. Can you rig that light to just work as a brake light?
