Is there a way to change the order of attachments in a post once they are attached?
I just replied to a members post with some information and pictures to try to help them out. The pictures were attached in the reverse order in which they were intended. I wanted to chance the order of the pictures to follow the narrative a little closer.
Also, is it possible to have some narrative followed by a picture followed by more narrative etc. in the same post? I thought I saw this done before, but when I just checked the Phazer FX engine teardown sticky, I saw it was done with several posts.
This would be very helpful in trying to do a technical write up.
Thanks.
Thanks.
You have to edit the posts and then edit the attachments, you can add info with the pic once in the edit window.
