SRX Boy
My 07 Phaser has the D light flashing - I can't get it into fad or reverse, light just flashes and when you give it gas it simply hesitate like Tors is on (short jumps fwd but does not run properly)
SRX Boy said:Did that - know the drill re:reverse. This problem is scary - like the machine is stuck between fwd and reverse.
cannondale27 said:SRX Boy said:Did that - know the drill re:reverse. This problem is scary - like the machine is stuck between fwd and reverse.
What type proximity switch tells the ecu its in reverse?That switch is where I would look.Is it adjustable?Magnetic?I dont have reverse on mine so not real familiar with it but thats where I would start.
same as mine usually shut it off only seems to happens though when i get in a hurry and hit the flipper before the blnking stops.pat the rat said:my d light flashes often,i just rock the sled back and fourth and it works almost everytime,if it doesnt work,i shut it off and restart it and usually its fine
