deerlodge
- May 1, 2003
- Orr,MN
- www.deerlodgeresort.com
RedRocket said:Sounds like the carbs were not put together correctly. They are opened via vacuum so if there is no vacuum or the Piston valve/spring was not put together right, then it will not open and suck in air/fuel.
Here is an exploded view of the carbs from a 2003 RX-1 service manual:
click thumbnails for larger images
thanks, im going to go thru the carbs tomorrow
deerlodge
- May 1, 2003
- Orr,MN
just did a compression test,
155,159,151,152
plugs have fuel on them and there is spark
155,159,151,152
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
any other symptoms? speedo not working, tail light out??? sounds electrical - you might be into a controller box or stator or something like that.
deerlodge
- May 1, 2003
- Orr,MN
no other symptoms, was running great and I decided to fix it now it runs on 2
I better stop opening my hood
deerlodge
- May 1, 2003
- Orr,MN
well I found the problem, I think.
when I push on the throttle part way only 2 of the valves on the back of the carbs open up.
deerlodge
- May 1, 2003
- Orr,MN
sent the carbs out to Jim(lakercr) and he fixed them up for me. ended up being a cracked spring. I finally got to race it this weekend, it was 50 degrees so the track was real soft. Still ended up doing 122 in a 1000'. sled ran great.
Thanks Jim for all the work you did on my sled last winter and with the carbs
