chadderbox
- Jan 4, 2015
- 2003 RX 1 LE (Silver)
Hi all , is there any way to stop my track from slipping without it being "guitar string" tight? lol
2003 RX1 . 121"
2003 RX1 . 121"
Grimm
Extrovert drive cogs on the driveshaft.
no, the only way is pull front limiter up a hole or 2 and keep a tight track... or go to extroverts.
chadderbox
- Jan 4, 2015
k thanks mr.sled & grimm, where's the best place to get themno, the only way is pull front limiter up a hole or 2 and keep a tight track... or go to extroverts.
I think Wahl Brothers or Avid from what hear, they are the best
chadderbox
- Jan 4, 2015
o k thank you,i'll pull straps up for now til' i find someI think Wahl Brothers or Avid from what hear, they are the best
Winderallday!
check your suspension arms for cracks/damage, also front suspension shock could be toast, seen it happen to a buds RX-1
keep in mind with extrovert drivers all windows in track must be open.
chadderbox
- Jan 4, 2015
ty,apex all day, good point on the windows , and i plan on upgrading the shocks w/in the next couple weeks and do a skid swap this summercheck your suspension arms for cracks/damage, also front suspension shock could be toast, seen it happen to a buds RX-1
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
To run extroverts in rx 1 you must trim them or they will hit the front arm.
I stock kimpex extroverts for only $70 a set. I can also sell whole shaft with a set pressed on if you don't have access to a press.
