Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
Here's what I have for stock springs
Dano74
- Nov 16, 2014
- 2008 Yamaha nytro rtx
The blue silver blue primary spring will likely be to soft, but the secondary spring is a keeper. I run a green white green primary spring with four 1mm shims at one end. Your dealer should have or can get em.Here's what I have for stock springs![]()
Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
Do you think it will work with the primary spring I have now?
Dano74
- Nov 16, 2014
I would think being that's the one that came with the weights .but I have no idea the rate on it or how stiff it is...just have to try it I guess.Do you think it will work with the primary spring I have now?![]()
Martens199
- Oct 1, 2012
- Saskatchewan, Canada
- 2008 Yamaha nytro 153 mcx190
2015 SRViper mtx se 162 mcx270
Probably their dalton red secondary spring. Suppose to act like a white stock but an inch longer for more pressure.
Gongshow77
- Sep 14, 2015
- 2014 Sr Viper XTX
So should I just leave the red one on or switch to the black?
