RAMSOMAIR
I'm sure the new braided hose will fit the older models, problem being the huge pain in the #*$&@ it is to get to and at it. The BOP covers are cheap and worked well on my 2017 for over 13000kms,
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for the reminder. Have been fortunate so far, but yes to adding that to the upcoming years preseason maintenance.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
It's not available yet! If the new hose is rigid you will probably need to remove the rear cooler and pipe running down the tunnel install the hose?Has anybody seen if it is possible to retrofit the metal braid hose they are using on the 2021 sleds onto our older models?
There is only a 1/4 " gap at the connection
Installing g a cover or stm tunnel protector would be much easier
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
- '18 Sidewinder XTX-SE
Installing g a cover or stm tunnel protector would be much easierView attachment 154541
As I have been thinking about that tube, I am going to replace it anyway. That little nick on mine isn't really leaking right now but that tube is not at full strength so I don't want to risk it blowing when I am riding alone and would need a sat phone to call for help.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
you have to drop the exchanger. one rivet over the driveshaft that you can chisel but not replace without removing shaft/track. 27 rivets
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
Do you have the part number for the braided hose? I am having difficulty to find what part number it is to even get an estimate of when it will be available.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
No it's not available yet and yamaha is not shipping anything to anyone including the dealers due to c19 in Canada not sure if it's the same in the USDo you have the part number for the braided hose? I am having difficulty to find what part number it is to even get an estimate of when it will be available.
SidewinderConvert
4-Stroke Rookie
- Mar 10, 2020
- Wisconsin
My dealer said that if I could find a part number he could get it still (if it is available).
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I don't believe part # available yet for any 2021 updates? If you find it please share!My dealer said that if I could find a part number he could get it still (if it is available).
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
@JMS@Yamaha
Guys are looking for the part number for the steel braided coolant hose for the heat exchanger.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
If you didn't have a leak on the stock hose I recommend either adding bop hose protectors, or getting stm tunnel protecters or making your own cover if you are handy!! Why drill out all the heat exchanger rivets if you don't need to???@JMS@Yamaha
To replace the hose you need to remove the pipe going the rear heat exchanger at minimum
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Already protected mine.
could you not add something like a thermal paste/adhesive where the protector touches the heat exchanger?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Now all ya need is the chaincase beefer up bracket that comes on the race sleds. Looks like the PERFECT time. 500 miles from now, thats what mine will look like.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Tell me more about this chaincase beef up bracket. This repair and hose protection I did last fall.
