FLYBYU
Why on a front mount can't get it to spool the turbo with a msd launch master?
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
YES you can!!!!!!!!
ultimate
- May 14, 2005
- ,Quebec
- uniklabels.com
- Yamaha apex
FLYBYU
Ted Jannetty is helping me out. He's the man
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Depends on lots of factors. Size of turbo, a/f ratio and ignition timing, heat of turbo and header, cams and cam timing.
Are you trying to pop it and spool the turbo?
Poping burns fuel out the header and superspools the turbo. If it dosnt pop it won't spool to high.
FLYBYU
oh yes, pops with flames
2854 garrett
stock timing
engine temp was 150
i'm sure turbo was hot
We think my engagement was too low
3400 to 3500 rpm
2854 garrett
stock timing
engine temp was 150
3400 to 3500 rpm
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
up the engagement........
3400 is too low
3400 is too low
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Go past 4000, more like 4300+ then you will have fireworks
FLYBYU
brought the engagement up to 5000 rpm. The first few times i tried it, the turbo spooled up. By the time i made it to the track it wouldn't build any boost again. Will it not pop as hard when the engine gets hotter? One guy i talked to at the track said that he had leaned his down alittle bit to get it to pop hard. Now to get Simons CPR stock settings for the pure logic controller. Anybody have them? Or anymore suggestions?
here you go, I just put a MSD master Launch on mine as well, just haven't gotten to fire it up any for more then a second.
heres the link to stock CPR numbers
FLYBYU
are you running the rb3 yet? I might switch to it. i need to get a better stutter that pulls timing and fuel to get it to pop better and spool the turbo for launch
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
FLYBYU
Mulot are you having the same problem?
I do have RB3 but the stutter option on that is a joke at best. I could only get 1-2 lbs boost built at the line. and that was set at 3400 RPM.
Once you get used to the RB3 it is so much better then the Pure Logic box. The sled runs so much nicer as well. But you have to get a lap top every time you want tot change. Dave at powderlites has some good base line maps, and depending on your set up. I have some real good maps that are good for 800-1000 above sea level that I could send you to try if you decide to go that route.
I cant wait to try the MSD though and see how that works!!
aj
aj
FLYBYU
Save your money on the msd. The only time i get it to pop good enough is when the engine is cold. and i still only get a couple of lbs of boost. Get a white heelclicker spring and bring your engagement up. It will bring it to about 5000 rpm. It will get the engine out of the bog range. We did it to switchbacks' sled this weekend and he took 1st in 700 mod and 2nd in 800 mod and i took 3rd in the same class. 3400 is to low. 4300 is about the lowest you can go. At least with the rb3 it pulls timing and fuel i believe which i need when the engine gets warm to get a good pop out of it which start to spool the turbo up
