HH question
Srxspec
Ulmer Racing
Tech Advisor
Menno, SD
Website
www.ulmerracing.com
2014 Yamaha SR Viper LTX, 2014 Yamaha SR Viper RTX SE, 2015 Yamaha SR Viper MTX SE 162 (turbo), 2015 Yamaha SR Viper MTX SE 153
LOCATION
Menno, SD
WEBSITE
www.ulmerracing.com
Can someone tell me what each piece in the HH set weighs? I'm looking for individual weights on each piece (allen screws, 7/16 bolts, all the washers, etc). Thanks.
Did you not get instructions with your Heavy Hitters?
If not maybe I could copy the info from my directions and post it.
I know some of them.
7/16 steel bolt is 4.2
thick washer is 1.4
thin washer is .4
3/8 steel bolt is 2.7
1/4" allen is .9
That is all I know off the top of my head.
brass bolt= 5.8
steel 7/16 bolt= 4.2
steel 3/8 bolt= 2.6
alum bolt= .9
thin washer= .4
thick washer =1.4
3/4 allen =3.3
1/2 allen =2.1
1/4 allen =.9
tungsten washers available in 3.4 and 5.3g...BBY
Mine is at exactly 49.4 grams each as stated in the instructions that came with the set. Different sets may vary a little in weight from set to set, but they are allways a balanced set.
