Kaz said:To me it looks like the bolt that retains the lower gear on the drive shaft and has back right out through the cover.
Time to take it a part and find out what's up. You need to repair that hole in the cover while your at it.
Kaz
Irv said:Is this somethng that could be common to all Yamaha sleds?
Still haven't gotten around to tearing into mine yet but hope to soon!![]()
Snowmobileaddict said:Irv said:Is this somethng that could be common to all Yamaha sleds?
This can happen to any sled from any brand if there is a bolt and washer holding the upper or lower gear on there respective shaft just inside the chaincase cover. The problem is usually when they are taken apart and then put back together without clean threads or lock-tite.
