Eh Pex
Is there a way to tell which lower bolt I have? What is the difference? Is it something that I should change (just to be safe)?...Good info/advice here...thanks,guys! Dan
Eh Pex............It's always cheaper to prevent a problem than to fix a problem. With that said, if you have never removed the chain case cover, I'd recommend you do so. In addition to cleaning out the gunk, check the torque on the driven gear bolt. If the bolt has never been removed, chances are that it's okay. I could not see any difference between the old and the new bolt.
