jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Well, searched everywhere on the internet with no luck. Thought I’d try here. Having an issue with my Honda eu1000 generator. I think it might be stator related. Does anyone know what the ohm reading should be on the subcoil on the stator? Seems the output voltage is low and someone told me the ohm reading should be around 300-500 ohm and I’m getting like 1 ohm. Generator also has lower than spec output voltage on main and sub coil from stator. Also my electronic throttle control doesn’t work.
from the readings you are getting i would say the stator is bad but i have never found the readings you are looking for either. hope someone else can help you out.
