houw mutch boost apex stock ignition
Turbor
mirabel,quebec,canada
Canada
sidewinder
how mutch boost can you run or how mutch hp in general will the stock apex ignition take before the spark starts to blow off?
anything over 17psi on mine and the spark starts to blow off tried cr9eix, cr10ek's at .20 gap to no avail, at 15-16 psi i have no ignition problems.
Your running Water/Meth also right?
What ratio, What nozzle, at what boost does it come in.
Apex injectors are taxed above 14 psi at sea level.
50-50 water and straight meth, 320cc single nozzle at inlet of intercooler and it comes in at 11 psi. stock motor 2 stacked gaskets. The meth allows me to be able to run more boost on the stock inj. My map in the rb3 is alot leaner than all the maps ive seen.
