Travis Moore
yammiman said:The fuel companies don't use the motor octance in their charts
http://www.rockettbrand.com/technicals/ ... gChart.pdf
So? The ONLY octane # that matters in regards to high performance engines is the motor octane #.
A
Anonymous
So what is the motoroctane of 91 premium then?
See TY "Sticky" in: Turbos/Supercharger Section
http://www.ty4stroke.com/viewtopic.php?t=29536
Specifically: Octane Boosters Link 1
http://www.europeancarweb.com/tech/0503ec_techboost
See charts provided:
http://www.europeancarweb.com/tech/0503ec_octane_boosters_tested/photo_11.html
http://www.europeancarweb.com/tech/0503ec_octane_boosters_tested/photo_12.html
Shows Shell 91-octane pump tested as: 96.3 RON & 87.9 MON divided by 2 = 92.1
A
Anonymous
So all I have to do is tank at shell premium and use the 87MON number in the formula!
seems pretty easy
50-50mix give me 102 MON then... and that is exactly what I need!
seems pretty easy
Yep, with a point or two safety margin.50-50mix give me 102 MON then... and that is exactly what I need!
Doesn't have to be Shell fuel... That's just "one example" of what you could get at the pump... It's a gamble every single time you go to the pump... That's why I don't run pump gas... I don’t have to allow myself that margin-of-error just in case I get piss-poor-fuel at the pump... Understandably, for the majority of riders, this is unreasonable, dollar-per-mile/availability/etc... It's not an issue for me so I burn a full 12 gallons ($80) worth of straight VP100 (unleaded, non-oxygenated, 96 motor octane) every ride... Box stock Apex/10lbs boost/small nitrous kicker/no worries.
Got my own little gas station.........
yammiman
.....The ONLY octane # that matters in regards to high performance engines is the motor octane #.....
If the octane needs to be that exact I wouldn't be trying to accomplish it with pump gas like HAMMER points out - I run a 50/50 mix in all of my high performance stuff primarily for the "insurance" factor plus everthing runs better and the race fuels have a much better shelf life
Why do the leaded race fuels have the same motor octane as they do R+M/2 octane when the unleaded race fuels are different by 4 to 5 points?
Travis Moore
Why is this tread still going? I anwsered the question asked like a week ago
yammiman
Travis Moore
yammiman said:We weren't aware that we needed your permission to keep talking!!
Get's old anwsering the same questions when the same topic is discussed monthly...
