rkkoeb
sideshowBob
What is the best way to remove and install the new carbon seal on the primary clutch spider on a 09 apex
The part you have in the picture is the “clutch cover” The “clutch spider” is the component the rollers attach to.
The best way to change the cover “bushing” is with a shop press.
rkkoeb
Do I need to lube the bushing when pressing it in
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
no don't lube just press it in.
RobX-1
- Coldwater, OH
I just replaced mine but damaged one trying to press it in myself. Tried the heat/cool method but only got bushing in part way and trying to get it in the rest of the way damaged it. Ended up having a buddy with a shop press install them and went in like butter.
blevis213
- Apr 13, 2013
- hadley, new york
- 2014 apex se
2001 srx 700
2000 srx 700
2021 sidewinder srx
I use a tab of blue loctite before pressing in and let dry overnight. You can buy a bushing tool https://www.ebay.ca/itm/Yamaha-Snow...sh=item4466b2dc77:g:zsMAAOSwm7Jfhfgh&vxp=mtri I have one works great for all bushings primary cover, inner bushing , and secondary bushing. also works on putting new bushings in helix's. On mine it has two part #'s ys-42424 and kl-0417L
rkkoeb
My buddy has a press at his work so he is going to try to press it in for me this week. Thanks for the suggestions
- 7K
