Cannondale - I'll add something to your point about clutch efficiency. I've had stock gearing on my RTX from the get go. When it was NA, the best top speed I got out of it was around 102. But it took absolutely perfect conditions, engine running well above 9000rpm, and the clutch working at it's best to get there. Essentially, with the hp available on the NA engine, you needed all the stars in perfect alignment to hit 100+ on trail conditions.
Since adding the turbo, I've still left stock gearing. And with the MPI kit, it's dangerous to run above 8600rpm unless further fuel mapping and fuel delivery mods are made. I've seen 106 as a top speed, and I have all the hp in the world to run out of gear now. But I think that tells you something about clutch efficiency as I now have enough hp to push the clutching to perform at it's best. Before = 102mph at 9000+rpm .... After = 106mph at 8600rpm .... Essentially, the before didn't have enough hp to overcome the load and clutching necessary to get big top speed numbers. So the only way to get there was to spin everything faster (aka running higher rpm). At least that's how it makes sense to me.
