1yamadog
would like to add a inch or two to the stock. leaning forward alittle so I thought that would help, and has anyone else done this to know how tall you can go with the stock cables. thanks
yamaslob
I know you can put a 2inch block over the stock bars with out getten cable extenders thats what the yami rep said. so idk
4Fighter
Confirmed: 2" I ran one for 2 seasons. You'll need to re-route the brake lines a bit.
Spyderman
Is that a powermadd riser block and do you just need to get longer bolts to use the factory riser block? I'm very interested in adding an inch or so to my bars, but not sure the best way to do it...
dirkdiggler
Suspended
Some one told me you should really use a solid riser. I belive the stock one is 6 inches tall. So if you want 8 inches you have to get a new 8 inch riser. I'm think the apex mountain riser is 8 plus.
richierich
stock is 4 1/4".i installed a 6" no problem.it actually rised it 6 1/2" with the mod.
Rash
the apex mountain is 2 inchs taller than the apex.. but i would like to go 1 inch taller.. the problem is finding 1 inch longer bolts??
RASH
RASH
justforme
i made a 1" spacer for mine. i got the bolts from http://www.mcmaster.com/
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
I would like to add about 2-3 " on mine, but I would also like to move it back too.
Would the Powermadd pivot work with a 8" riser?
Or will it be enough with the stock riser?
Red2003
I have an 8 in. power madd riser block in he classifieds!
Nice Rumble
Yo Just! I sent you a P.M.
Nice Rumble
justforme said:i made a 1" spacer for mine. i got the bolts from http://www.mcmaster.com/
Do you have part the numbers or know the bolt size you used to order from mcmaster? I need to order a set.
