geez150
I was just out in the garage looking at mine. I took the vent line off and blew into it and it seems clear. Then I blew into the tank and could hear that high pitch pressure sound. It is coming from the check valve that the over flow line attaches to. So I wonder if the sleds that build the pressure have bad check valves?
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Has anyone had a intermittent, rough, low idle with bad mileage and had it fixed by the new return elbow or fuel pressure regulator?
**sj**
Yes
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
Did you replace the elbow or was it the regulator? What was it doing at idle
**sj**
Elbow... Very rich... Elbow... Regulator or fuel pump can cause running issues... What's your problems
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
I almost always have to start it with a little throttle, about 50% of the time it idles low and rough. One time I let it idle low and rough without hitting the throttle and it dropped a cylinder. I am planning on bringing it to the dealer soon and just want to have my ducks in a row. The gas tank always has pressure too but I think they are supposed to?Elbow... Very rich... Elbow... Regulator or fuel pump can cause running issues... What's your problems
**sj**
gas tank is supposed to hold vapor...yes...the quickest and easiest first step is to swap the elbows....or you can drill the stock one out....ask me for procedure....you'll know pretty much right away
geez150
I have replaced the elbow and pressure regulator trying to up my mpg with no luck. But my sled runs good. No run issues or idle issues.
- 12K
