sleddheadd
looks Sweet!
bdm said:When I did mine a couple of years ago I had two problems:
1) It is good that RM used a baffle. Without a baffle the glasspack resonated in my helmet something awful. I added a CC insert and that took care of it.
2) I am not sure if this problem was exhaust related but twice last season in bottomless powder I had a bog that was similar to if all of the hood vents were blocked, yet they were clear. In hopes that there was some kind of backpressure issue related to powder in the area between the track and the tunnel I extended the outlet to come out further back - way under the tunnel extension. We will see if that helps.
kyzer said:Looks great I know another guy that did something very similar , the only problem was the tunnel built up with ice really fast , ( same issue as the Venture Lite and some Phazers ) ...The hot exhaust melts the snow and the snow dust kicked up from the track ..it was a real pain in the #*$&@ ....You can get a couple hundred pounds of ice built up under there .....Hopefully you don't have the same issue ...His solution was to extent it and bend it out the side of the tunnel...........
kyzer said:I don't think it's the heat form the exhaust it's self , but the hot exhaust air coming out ......When it's trapped underneath for a bit the hot air melt all the snowdust to the inside of the tunnel and it keeps building up....
Firemann32 said:What year and model sled was this mod done on?
Reason I ask is the 1 Adapter NAPA# 735-1626 2-1/4 ID x 2" OD didn't fit. It needs to be larger than 2-1/4 on an 07' Apex Mtn.
