TurboBuRick
- Dec 27, 2010
I have a friend who has a Apex that can lift the skis pretty much on Que.
2006 rtx. No real mods. Just picks as far as I can tell.
I have a 2006 gt that will not come up. Same picks in track. It will not pull the ski's.
I'm thinking his clutch is making the difference. Looking for some input.
TIA
RL
TIA
RL
ZapeX2
loosen transfer rod and limiter strap= hang on.... nothing to do with clutching.... all weight transfer...
If stock they both have the exact same clutching and gearing. My buddy's 06 RTX can wheelie and demand too and its all stock. Not sure why but if we ever get enuf snow we are going to correct that problem.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
04Brian said:loosen transfer rod and limiter strap= hang on.... nothing to do with clutching.... all weight transfer...
X2
snoprof6
- Mar 26, 2007
- Upstate NY
- 20 Indy XCR
16 Zr 6000 LTD
02 Sx Viper
02 Sx Viper
you got 150 ponies and a butt load of torque.... pinn'er haha
TurboBuRick
- Dec 27, 2010
Thanks for the reply.
The strap is on the last set of holes and about 5/8 worth of threads showing on the rod now. Loosen rod so more threads are showing?
TIA
- Jun 28, 2004
- Clinton, Wi.
The RTX is geared lower. Your options have alreadt been listed. Let the limiter all the way out and set the transfer rod to MAX. You won't have good cornering, but it'll wheelie LOL.
Viper_Dave said:The RTX is geared lower.
I thot in 06 they were all geared the same. At least in the tech section they are listed as the same. The only one that has diff gearing is the Attak
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
In 06 same gearing. 07, rtx was different.
sherlock29
take your transfer rod out.... she will come up.
