Has anyone put a attack skid on a warrior? Should you buy the attack mounting plates? Can you reuse the stock mounts and relocate them?
Any help would be great.
I have found so far that the stock rivits line up with the stock mounts of the mono susp. All you have to do is drill out the stock ones and drill for the new bolts and extra rivits and youre set and hole saw for adj. nob. It is not totally done yet but I think it will work. The key is getting the stock mounting plates from the Apex.
